Zum Hauptinhalt wechseln
Omaker M4 Port Cover Replacement
Was du brauchst
  1. Omaker M4 Port Cover Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: Schritt 2, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 2, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: Schritt 3, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 3, Bild 2 von 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: Schritt 5, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 5, Bild 2 von 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: Schritt 6, Bild 1 von 2 Omaker M4 Port Cover Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: Schritt 7, Bild 1 von 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: Schritt 8, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 8, Bild 2 von 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: Schritt 9, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 9, Bild 2 von 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: Schritt 10, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 10, Bild 2 von 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: Schritt 11, Bild 1 von 2 Omaker M4 Port Cover Replacement, Port Cover: Schritt 11, Bild 2 von 2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: Schritt 12, Bild 1 von 1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: Schritt 13, Bild 1 von 2 Omaker M4 Port Cover Replacement: Schritt 13, Bild 2 von 2
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: Schritt 14, Bild 1 von 1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 2-2, Sullivan Spring 2016 Mitglied von USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 353
