Einleitung
This guide will show you how to replace a battery that no longer works. This is a common problem with any electronic device and is an easy fix. Just remember to turn the power off before you begin, and to be gentle with the battery. A damaged battery could catch on fire or explode.
Was du brauchst
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Carefully pry the battery away from the back panel using the nylon or metal spudger.
Gently remove the battery from the back panel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
