Einleitung
This guide will allow you to remove the screen from the inside of the device in order to clean it or replace it. The screen on a device can easily crack. This repair is easy to do and does not require any special tools.
Was du brauchst
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
