Einleitung
This guide will show you how to replace a speaker that no longer works. This is a common problem with any electronic device and is an easy fix. Just remember to turn the power off before you begin, and to be careful when using soldering tools.
Was du brauchst
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Desolder the black(-) and red(+) wires connecting the speaker to the motherboard using a soldering iron and tweezers to hold the wire.
