Zum Hauptinhalt wechseln
One Education Infinity:One Camera Assembly Replacement
Was du brauchst
  1. One Education Infinity:One Camera Assembly Replacement, Battery: Schritt 1, Bild 1 von 2 One Education Infinity:One Camera Assembly Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Camera Assembly Replacement: Schritt 2, Bild 1 von 3 One Education Infinity:One Camera Assembly Replacement: Schritt 2, Bild 2 von 3 One Education Infinity:One Camera Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Camera Assembly Replacement: Schritt 3, Bild 1 von 3 One Education Infinity:One Camera Assembly Replacement: Schritt 3, Bild 2 von 3 One Education Infinity:One Camera Assembly Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Camera Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: Schritt 5, Bild 1 von 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: Schritt 5, Bild 2 von 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: Schritt 5, Bild 3 von 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  6. One Education Infinity:One Camera Assembly Replacement: Schritt 6, Bild 1 von 2 One Education Infinity:One Camera Assembly Replacement: Schritt 6, Bild 2 von 2
    • Use tweezers to remove the black cushion surrounding the camera lens.
  7. One Education Infinity:One Camera Assembly Replacement: Schritt 7, Bild 1 von 2 One Education Infinity:One Camera Assembly Replacement: Schritt 7, Bild 2 von 2
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
Abschluss
Taylor Bratsch
5.742 Reputation
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 182
