Einleitung
This guide will detail how to replace the display assembly in the One Education Infinity:One laptop. After completion of this guide, the digitizer and screen will be separated to allow for replacement of either component.
Was du brauchst
Insert a Jimmy or other prying tool into the seam between the screen and back case.
Trace around the edges until all clips are released.
Lift the back case away from the tablet.
Use a spudger to release the speaker wires by pushing the bundled cabled connector away from the motherboard.
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use a spudger to lift the black tab on top of the ZIF connector.
Slide the ribbon cable out of the connector.
Use a spudger to flip up the black retaining flap on the ZIF connector.
Pull the folded ribbon cable straight out of the connector.
Use a spudger to flip up the black flap on the camera's ZIF connector.
Pull the ribbon cable straight out of the connector.
Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
Unscrew the five 4.2mm screws with a Phillips #000 screwdriver.
Use a spudger to lift the digitizer away from the screen.
Grasp the edge of the digitizer and lift straight up to remove.
