Zum Hauptinhalt wechseln
One Education Infinity Solid State Drive Replacement
Was du brauchst
  1. One Education Infinity Solid State Drive Replacement, Back Case: Schritt 1, Bild 1 von 3 One Education Infinity Solid State Drive Replacement, Back Case: Schritt 1, Bild 2 von 3 One Education Infinity Solid State Drive Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Solid State Drive Replacement: Schritt 2, Bild 1 von 2 One Education Infinity Solid State Drive Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Solid State Drive Replacement: Schritt 3, Bild 1 von 3 One Education Infinity Solid State Drive Replacement: Schritt 3, Bild 2 von 3 One Education Infinity Solid State Drive Replacement: Schritt 3, Bild 3 von 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Solid State Drive Replacement, Battery: Schritt 4, Bild 1 von 3 One Education Infinity Solid State Drive Replacement, Battery: Schritt 4, Bild 2 von 3 One Education Infinity Solid State Drive Replacement, Battery: Schritt 4, Bild 3 von 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Solid State Drive Replacement: Schritt 5, Bild 1 von 3 One Education Infinity Solid State Drive Replacement: Schritt 5, Bild 2 von 3 One Education Infinity Solid State Drive Replacement: Schritt 5, Bild 3 von 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Solid State Drive Replacement, Solid State Drive: Schritt 6, Bild 1 von 3 One Education Infinity Solid State Drive Replacement, Solid State Drive: Schritt 6, Bild 2 von 3 One Education Infinity Solid State Drive Replacement, Solid State Drive: Schritt 6, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Solid State Drive Replacement: Schritt 7, Bild 1 von 3 One Education Infinity Solid State Drive Replacement: Schritt 7, Bild 2 von 3 One Education Infinity Solid State Drive Replacement: Schritt 7, Bild 3 von 3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
Abschluss
Cal Poly, Team S11-G4, Regan Fall 2019 Mitglied von Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 277
