Einleitung
This guide will detail how to safely remove the speakers from the One Education Infinity laptop. The model number for the Infinity is A03. This device can be recognized by its dark grey exterior, light grey interior, purple carrying handle, and rotating camera above the screen.
The Infinity was released in Spring 2019 and is NOT the same as the Infinity: One.
Was du brauchst
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
Lift the back case off of the device.
Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
Lift the battery out from the internal case.
Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
Grab the SSD with your fingers and slide it slowly to the right and out of its port.
Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
Using your fingers, carefully unplug the two speaker wires from the motherboard.
Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
Using your fingers, carefully lift the motherboard out of the internal panel.
Peel back the black tape.
Using your fingers, carefully lift the metal plate out of the internal panel.
Using your fingers, carefully lift the two speakers out of the internal panel.
