Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you how to remove the back case of the One Education Infinity:One laptop. This should be used to replace a damaged back cover, or to gain access to internal components for more complex repairs.
  1. Use a spudger to pry the four rubber pads away from the bottom of the case. Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. Insert a Jimmy or other prying tool into the seam on the edge of the casing. Trace along the edges of the device until all clips are released.
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  5. Use tweezers to lift the fabric cover and hinge connector away from the daughterboard. Always use ESD safe tools when working with delicate electrical components.
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
Abschluss
Taylor Bratsch
4.583 Reputation
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 68
