Einleitung
This guide will detail how to safely remove the battery from the One Education Infinity:One laptop.
Was du brauchst
Insert a Jimmy or other prying tool into the seam between the screen and back case.
Trace around the edges until all clips are released.
Lift the back case away from the tablet.
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use a spudger to lift the black tab on top of the ZIF connector.
Slide the ribbon cable out of the connector.
Use a spudger to flip up the black retaining flap on the ZIF connector.
Pull the folded ribbon cable straight out of the connector.
Eine weitere Person hat diese Anleitung absolviert.
