Zum Hauptinhalt wechseln
One Education Infinity:One Hinge Contact Assembly Replacement
Was du brauchst
  1. One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: Schritt 1, Bild 1 von 2 One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 2, Bild 1 von 2 One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 2, Bild 2 von 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 4, Bild 1 von 2 One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 4, Bild 2 von 2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: Schritt 5, Bild 1 von 2 One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: Schritt 5, Bild 2 von 2
    • Lift the hinge away from the device.
  6. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the two 6.5mm screws.
  7. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 7, Bild 1 von 2 One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 7, Bild 2 von 2
    • Slide a Jimmy or other prying tool along the seam of the hinge to pry the casing apart.
  8. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two 4.3mm screws holding the circuit board in place.
  9. One Education Infinity:One Hinge Contact Assembly Replacement: Schritt 9, Bild 1 von 1
    • Use a spudger to pry the circuit board away from the casing.
    • Always use ESD safe tools when removing delicate components.
Abschluss
Taylor Bratsch
5.742 Reputation
14 Anleitungen geschrieben
Ein Kommentar
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
Nathan Joyce - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 198
