Zum Hauptinhalt wechseln
Einleitung
This guide will demonstrate how to replace the motherboard in your One Education Infinity:One laptop.
  1. Use a spudger to disconnect the black bundled cable connector from the motherboard. Use a spudger to disconnect the black bundled cable connector from the motherboard.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. Use a spudger to lift the black tab on top of the ZIF connector. Slide the ribbon cable out of the connector. Slide the ribbon cable out of the connector.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. Use a spudger to flip up the black retaining flap on the ZIF connector. Pull the folded ribbon cable straight out of the connector. This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. Use a spudger to pry the battery away from the device.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. Use ESD safe tweezers to disconnect the antenna from the motherboard. Use ESD safe tweezers to disconnect the antenna from the motherboard.
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  7. Use a spudger to flip up the black flap on the camera's ZIF connector. Pull the ribbon cable straight out of the connector. Pull the ribbon cable straight out of the connector.
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  8. Use tweezers to pull the dock connection cable away from the motherboard.
    • Use tweezers to pull the dock connection cable away from the motherboard.
  9. Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  10. Lift the protective shield away from the motherboard.
    • Lift the protective shield away from the motherboard.
  11. With the flat end of a spudger, flip up the black flap on the display's ZIF connector. Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector. During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  12. Gently lift the motherboard away from the display assembly.
    • Gently lift the motherboard away from the display assembly.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Taylor Bratsch
3.600 Reputation
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 166
