Einleitung
If you need to replace the motherboard of your OneLink Safe and Sound, follow this guide.
Was du brauchst
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
Use the plastic opening tool to remove the microphone connection from the motherboard.
Remove the top of the device.
Use the plastic opening tool to disconnect the cable from the motherboard.
Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
Remove the plastic cage holding the battery in place.
Remove the battery from the device.
Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
Use the opening tool to disconnect the speaker cables from the daughterboard.
Use the opening to lift the daughterboard off of the motherboard.
Use a Phillips #0 screwdriver to remove seven screws securing the white base and motherboard.
