Einleitung
This guide will give a step by step instruction on how to safely remove the components leading up to the front facing camera.
Was du brauchst
Use a heat gun to gently heat the back edges of the phone to loosen the adhesive.
Use a plastic opening tool to pry the back cover up.
Carefully lift the back cover off.
Use tweezers to disconnect the red pull-away tab up from the motherboard.
Detach the orange camera ribbon cable, below the red tab, using the tweezers.
Grip the green tab and lift the battery up and out of the chassis.
Use a Phillips #000 screwdriver to remove the ten screws from the motherboard harness.
Pull the motherboard harness up using the tweezers
Use the pointed tip of a spudger to lift the front-facing camera's pin connection, gently prying on the plug vertically until it completely releases.
Lift the front-facing camera up and out using tweezers.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
