Einleitung
OnePlus 6T was the flagship killer launched by the Chinese brand in November 2018. One of the major upgrades from its OnePlus 6 model, was the in-screen fingerprint scanner alongside other hardware updates. 6T featured a dual-camera setup at the rear (16+20 MP) and was the best camera launched by the company until the OnePlus 7 in the following year. This post helps you replace that setup and its detailed explanation ensures that you perform this procedure in the best way possible.
Was du brauchst
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
Carefully remove the SIM card from its tray.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
Remove the front camera from the phone.
Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
Use a spudger to disconnect the signal cables on the right side of the motherboard.
Disconnect the slider from the top of the phone with a spudger.
Gently pull the motherboard from the left side and remove it from the phone.
Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
Remove the camera from its slot on the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
