Einleitung
Replace the power fuse for the Onkyo TX800 receiver.
  1. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Remove the top screw on the back panel. Remove the top screw on the back panel.
    • Remove the top screw on the back panel.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
    • Slide off the case to expose the internal components of the receiver.
  5. Locate the fuse. Locate the fuse.
    • Locate the fuse.
  6. Gently wedge a small screwdriver in between one side of the fuse and the contact. Remove the fuse with your thumb and forefinger.
    • Gently wedge a small screwdriver in between one side of the fuse and the contact.
    • Remove the fuse with your thumb and forefinger.
  7. Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
    • Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
Ziellinie
4 weitere Nutzer haben diese Anleitung absolviert.
Michael Lady
241 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 27-92, Amido Spring 2010 Mitglied von Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Mitglieder
7 Anleitungen geschrieben
Thanks for clear instructions!
Andy Dersch - Antwort
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 136
All Time: 10,046
