Einleitung
Learn how to assemble the open-storm GI node. This includes pairing a pressure transducer, soil moisture sensor, and matboxic depth sensor.
  1. Make sure you have the following:
    • Make sure you have the following:
    • Real-Time Water Systems Cell Board
    • PSoC USB connector
    • Maxbotix Sonar Depth Sensor
    • SM3 Soil Moisture Probe
    • Pressure Transducer.
  2. In order to use the Open-Storm Cell Board, you need to connect certain pins on the board by using jumpers. Jumps are black, and connect two pins. Jumpers allow users to toggle options on the board, such as power supply voltage or making it possible for the Cell Board to be programmed using PSoC software.
    • In order to use the Open-Storm Cell Board, you need to connect certain pins on the board by using jumpers.
    • Jumps are black, and connect two pins.
    • Jumpers allow users to toggle options on the board, such as power supply voltage or making it possible for the Cell Board to be programmed using PSoC software.
    • See pictures for proper orientation of jumpers on pins.
  3. First screw in the wires into the ultrasonic sensor Next screw in the wires into a terminal block
    • First screw in the wires into the ultrasonic sensor
    • Next screw in the wires into a terminal block
    • Then insert the terminal block into the board as shown
    • Pay careful attention to the pin locations on the board.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Soil Moisture and Pressure transducer share the same supply voltage, therefore you will need to take care to connect them at the same time. See next step for complete connections. See next step for complete connections.
    • Soil Moisture and Pressure transducer share the same supply voltage, therefore you will need to take care to connect them at the same time.
    • See next step for complete connections.
  6. Jumper wire provides power to pressure transducer.
    • Jumper wire provides power to pressure transducer.
  7. Connect PSoC USB connector to board. Connection is uni-directional. Take care that it is properly connected before inserting USB side into computer.
    • Connect PSoC USB connector to board.
    • Connection is uni-directional. Take care that it is properly connected before inserting USB side into computer.
  8. Find the latest version here: https://github.com/open-storm/perfect-ce...
Ziellinie
Gregory Ewing
229 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 65
