Was du brauchst
This camcorder is a 720p HD camcorder that costs very little.
The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens.
Now remove the two s screws highlighted in red.
Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
On the right side (battery door hatch side), there is another screw under a black dot.
Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
