Einleitung
How to open your Link.usb Audio Interface device despite no visible screws.
Was du brauchst
Put the device in front of you, with the knob labels the right side up
Pry the rubber off the top of the device
All the rubber
Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
5 screw holes will appear. Leave them alone for now.
Look at the side of the device with the metal stand
Take a heat gun to the two small foam pads
You only need to pry off the halves on the top plastic shell
Put scraps of glossy paper on the foam pads to prevent them from sticking on again
Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
You could now lift out the whole innards
They are not attached to the bottom shell
No, the mess of glue is how it left the factory
