Zum Hauptinhalt wechseln
Opening Tapco Link Series device
Was du brauchst
  1. Opening Tapco Link Series device, Introduction: Schritt 1, Bild 1 von 1
    • Put the device in front of you, with the knob labels the right side up
  2. Opening Tapco Link Series device, Revealing Screws: Schritt 2, Bild 1 von 2 Opening Tapco Link Series device, Revealing Screws: Schritt 2, Bild 2 von 2
    • Pry the rubber off the top of the device
    • All the rubber
    • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
    • 5 screw holes will appear. Leave them alone for now.
  3. Opening Tapco Link Series device: Schritt 3, Bild 1 von 2 Opening Tapco Link Series device: Schritt 3, Bild 2 von 2
    • Look at the side of the device with the metal stand
    • Take a heat gun to the two small foam pads
    • You only need to pry off the halves on the top plastic shell
    • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
    • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
  4. Opening Tapco Link Series device: Schritt 4, Bild 1 von 2 Opening Tapco Link Series device: Schritt 4, Bild 2 von 2
    • Now remove the 5 Philips screws on top
  5. Opening Tapco Link Series device: Schritt 5, Bild 1 von 1
    • Simply lift off the top
    • No clips anywhere
  6. Opening Tapco Link Series device: Schritt 6, Bild 1 von 1
    • You could now lift out the whole innards
    • They are not attached to the bottom shell
    • No, the mess of glue is how it left the factory
Abschluss
Tobias
10 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 204
