Was du brauchst
Tool on left - PH000 screwdriver
Tool on right - iPod fix-it tool
Soldering Iron
Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
