Zum Hauptinhalt wechseln
Opening the Column in the Hamilton Galileo
Was du brauchst
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: Schritt 1, Bild 1 von 1
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: Schritt 3, Bild 1 von 1
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: Schritt 4, Bild 1 von 2 Opening the Column in the Hamilton Galileo: Schritt 4, Bild 2 von 2
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Abschluss
Ian Van Sciver
332 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S7-G26, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 139
