Einleitung
Use this guide to remove the color wheel from your Optoma HD20.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
Using a flat head screw driver unscrew the back part to release the color wheel.
5 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter -
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter -
It literally pops off. It has 3 slips on it but they all undo at the same time you pull it straight out.
