Zum Hauptinhalt wechseln
Optoma HD20 Fan Replacement
Was du brauchst
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 1 von 2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 2 von 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Fan Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Fan Replacement: Schritt 4, Bild 1 von 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Fan Replacement, Fan: Schritt 5, Bild 1 von 1
    • Peel off the tape that is holding the metal casing down.
  6. Optoma HD20 Fan Replacement: Schritt 6, Bild 1 von 2 Optoma HD20 Fan Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
  7. Optoma HD20 Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the metal casing by lifting it up off of the circuit board.
  8. Optoma HD20 Fan Replacement: Schritt 8, Bild 1 von 1
    • Unplug the six wires stemming from the circuit board.
  9. Optoma HD20 Fan Replacement: Schritt 9, Bild 1 von 1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
  10. Optoma HD20 Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
  11. Optoma HD20 Fan Replacement: Schritt 11, Bild 1 von 1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
  12. Optoma HD20 Fan Replacement: Schritt 12, Bild 1 von 1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
  13. Optoma HD20 Fan Replacement: Schritt 13, Bild 1 von 1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
  14. Optoma HD20 Fan Replacement: Schritt 14, Bild 1 von 1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
  15. Optoma HD20 Fan Replacement: Schritt 15, Bild 1 von 2 Optoma HD20 Fan Replacement: Schritt 15, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
  16. Optoma HD20 Fan Replacement: Schritt 16, Bild 1 von 2 Optoma HD20 Fan Replacement: Schritt 16, Bild 2 von 2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Trever
1.262 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-23, Maness Winter 2015 Mitglied von Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Mitglieder
6 Kommentare
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Antwort
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Antwort
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague -
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Antwort
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 70
Insgesamt: 12,384
