Zum Hauptinhalt wechseln
Optoma PRO360W Bulb Replacement
Was du brauchst
  1. Optoma PRO360W Bulb Replacement, Unplug projector: Schritt 1, Bild 1 von 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: Schritt 2, Bild 1 von 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: Schritt 4, Bild 1 von 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: Schritt 5, Bild 1 von 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: Schritt 6, Bild 1 von 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: Schritt 7, Bild 1 von 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: Schritt 8, Bild 1 von 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: Schritt 9, Bild 1 von 1
    • Dispose of the bulb by sending it to a recycling center.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Desiree Benitez
128 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017
USFSM-STEWART-S17S1G1
19 Mitglieder
22 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 844
