Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Electric toothbrushes are powered by a rechargeable battery, that enables the reciprocating brushing motion of the bristles. If your electric toothbrush loses power quickly or doesn't hold charge, most likely the rechargeable battery needs to be replaced.
  1. Pull off head, and use pliers to remove the white cap. Pull out the circuit core. Pull off head, and use pliers to remove the white cap. Pull out the circuit core. Pull off head, and use pliers to remove the white cap. Pull out the circuit core.
    • Pull off head, and use pliers to remove the white cap. Pull out the circuit core.
  2. De-solder in these four (4) locations. The two (2) motor connections
    • De-solder in these four (4) locations.
    • The two (2) motor connections
    • The Positive (+) side of the battery
    • The Negative (-) side of the battery
  3. De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board. De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board.
    • De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. De-Solder the three (3) upper terminals from the circuit board.
    • De-Solder the three (3) upper terminals from the circuit board.
  6. Use plastic prying tools to carefully pry off the circuit board. (Utilize metal spedger as a last resort)
    • Use plastic prying tools to carefully pry off the circuit board. (Utilize metal spedger as a last resort)
    • There is a white tab that goes through the board, be careful when removing the circuit board.
  7. Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board
    • Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board
  8. When re-installing battery, remember to bend down lower terminal. And the negative (-) terminal is closest to the copper wires
    • When re-installing battery, remember to bend down lower terminal. And the negative (-) terminal is closest to the copper wires
    • Ensure you recharge the toothbrush after the repair. Even if the replacement battery is already fully charged, the toothbrush will fail to power on if you don’t recharge the toothbrush.
Abschluss
To reassemble your device, follow these instructions in reverse order. Remember to apply just enough solder to re-attach the terminals.
6 weitere Nutzer haben diese Anleitung absolviert.
Miles Gunty
252 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G1, Harley Fall 2017 Mitglied von IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
3 Mitglieder
4 Anleitungen geschrieben
This is very easy to do. I had no problems following your instructions.
Ian Bowker - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 21
Letzten 7 Tage: 191
Letzten 30 Tage: 875
Insgesamt: 12,397
