Einleitung
This guide covers the steps to remove and replace the broken screen on your Orbic wonder. Some steps are repeated, as this is a guide made up of other guides.
Was du brauchst
There is a border between the black phone backing and the silver screen.
Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
When the halves are parted correctly, the gap should look like this.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
There is a black flap on the bottom of the battery.
Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
Use a pair of angled tweezers to remove the speaker housing.
Detach the metal casing at the bottom of the phone.
Unplug the cable connector.
Use a pair of angled tweezers to unplug the black wire.
Using a pair of angled tweezers, disconnect the connector chip.
With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
Disconnect the "L" shaped plug connecting the battery to the circuit board.
Carefully disconnect the small gold connecting wire.
Disconnect the rectangular piece.
Unplug the power button connector.
Unplug the circuit connector above the battery.
Carefully remove the protective sticker. This will expose the camera and its connector.
The circuit board should now be loose. Disconnect it, and remove it from the phone housing.
Using the iOpener, heat the screen's edges to loosen the adhesive holding the screen in place.
Using the Jimmy and opening picks, gently pry the screen from the phone housing.
Push the gold lower screen connector wire through the hole.
Do the same to the gold upper screen connector wire.
Using your hands, separate the screen from the rest of the phone, ensuring that the connector wires go through the openings without ripping.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
