Zum Hauptinhalt wechseln
Ordro HDV-D395 Back Case Replacement
Was du brauchst
  1. Ordro HDV-D395 Back Case Replacement, Back Case: Schritt 1, Bild 1 von 2 Ordro HDV-D395 Back Case Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Back Case Replacement: Schritt 2, Bild 1 von 1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Back Case Replacement: Schritt 3, Bild 1 von 1
    • Unfold the screen from the side of the camera.
  4. Ordro HDV-D395 Back Case Replacement: Schritt 4, Bild 1 von 1
    • Twist the screen so that the screen is facing downward.
  5. Ordro HDV-D395 Back Case Replacement: Schritt 5, Bild 1 von 2 Ordro HDV-D395 Back Case Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
    • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
  6. Ordro HDV-D395 Back Case Replacement: Schritt 6, Bild 1 von 1
    • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
  7. Ordro HDV-D395 Back Case Replacement: Schritt 7, Bild 1 von 2 Ordro HDV-D395 Back Case Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
    • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
  8. Ordro HDV-D395 Back Case Replacement: Schritt 8, Bild 1 von 1
    • Take the back case off by pulling it away from the main body.
    • Be careful not to tear the white strap that connects the back case to the main body.
  9. Ordro HDV-D395 Back Case Replacement: Schritt 9, Bild 1 von 1
    • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
  10. Ordro HDV-D395 Back Case Replacement: Schritt 10, Bild 1 von 1
    • Pull the board away from the back case.
Abschluss
Mostafa Abdulaleem
181 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G3, Baechle Fall 2018 Mitglied von IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 301
