Einleitung
If the buttons in the back case of your camcorder are broken, you can replace them by following these steps.
Was du brauchst
Pull the slider labeled open, on the bottom right, to unlock the battery.
Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
