Zum Hauptinhalt wechseln
Oregon Scientific Meep! X2 Battery Replacement
Was du brauchst
  1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: Schritt 1, Bild 1 von 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Battery Replacement: Schritt 2, Bild 1 von 3 Oregon Scientific Meep! X2 Battery Replacement: Schritt 2, Bild 2 von 3 Oregon Scientific Meep! X2 Battery Replacement: Schritt 2, Bild 3 von 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Battery Replacement: Schritt 3, Bild 1 von 3 Oregon Scientific Meep! X2 Battery Replacement: Schritt 3, Bild 2 von 3 Oregon Scientific Meep! X2 Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: Schritt 4, Bild 1 von 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: Schritt 4, Bild 2 von 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: Schritt 4, Bild 3 von 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  5. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: Schritt 5, Bild 1 von 2 Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: Schritt 5, Bild 2 von 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  6. Oregon Scientific Meep! X2 Battery Replacement: Schritt 6, Bild 1 von 2 Oregon Scientific Meep! X2 Battery Replacement: Schritt 6, Bild 2 von 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Abschluss
USF Tampa, Team 9-1, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 1,463
