Einleitung
Follow this guide in order to fix the cameras in your Oregon Scientific Meep! X2 tablet.
Was du brauchst
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
Use the plastic opening tools to undo the clips around the edges of the device.
Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
Release the black security clip on the ribbon cable with your plastic opening tool.
Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
