Einleitung
Use this guide to replace a faulty microphone unit in your Oregon Scientific Meep! X2 tablet.
Was du brauchst
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
Use the plastic opening tools to undo the clips around the edges of the device.
Use your tweezers to gently remove the microphone from the slot in the casing.
