Zum Hauptinhalt wechseln
Oregon Scientific Meep! X2 Microphone Replacement
Was du brauchst
  1. Oregon Scientific Meep! X2 Microphone Replacement, Rear Casing: Schritt 1, Bild 1 von 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Microphone Replacement: Schritt 2, Bild 1 von 3 Oregon Scientific Meep! X2 Microphone Replacement: Schritt 2, Bild 2 von 3 Oregon Scientific Meep! X2 Microphone Replacement: Schritt 2, Bild 3 von 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Microphone Replacement: Schritt 3, Bild 1 von 3 Oregon Scientific Meep! X2 Microphone Replacement: Schritt 3, Bild 2 von 3 Oregon Scientific Meep! X2 Microphone Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Microphone Replacement, Microphone: Schritt 4, Bild 1 von 2 Oregon Scientific Meep! X2 Microphone Replacement, Microphone: Schritt 4, Bild 2 von 2
    • Use your tweezers to gently remove the microphone from the slot in the casing.
  5. Oregon Scientific Meep! X2 Microphone Replacement: Schritt 5, Bild 1 von 2 Oregon Scientific Meep! X2 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Unsolder the microphone unit from the motherboard using the soldering station.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Abschluss
USF Tampa, Team 9-1, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 191
