Einleitung
Use this guide to replace a jammed or broken power button in the Oregon Scientific Meep! X2 tablet.
Was du brauchst
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
Use the plastic opening tools to undo the clips around the edges of the device.
Use a tweezer to gently pull the power button sensor out of the case's slot.
Use the soldering station to unsolder and remove the power button from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
