Zum Hauptinhalt wechseln
Oregon Scientific Meep! X2 Screen Replacement
Was du brauchst
  1. Oregon Scientific Meep! X2 Screen Replacement, Rear Casing: Schritt 1, Bild 1 von 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Screen Replacement: Schritt 2, Bild 1 von 3 Oregon Scientific Meep! X2 Screen Replacement: Schritt 2, Bild 2 von 3 Oregon Scientific Meep! X2 Screen Replacement: Schritt 2, Bild 3 von 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Screen Replacement: Schritt 3, Bild 1 von 3 Oregon Scientific Meep! X2 Screen Replacement: Schritt 3, Bild 2 von 3 Oregon Scientific Meep! X2 Screen Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Screen Replacement, Power Button: Schritt 4, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Power Button: Schritt 4, Bild 2 von 2
    • Use a tweezer to gently pull the power button sensor out of the case's slot.
  5. Oregon Scientific Meep! X2 Screen Replacement: Schritt 5, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 5, Bild 2 von 2
    • Use the soldering station to unsolder and remove the power button from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
  6. Oregon Scientific Meep! X2 Screen Replacement, Microphone: Schritt 6, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Microphone: Schritt 6, Bild 2 von 2
    • Use your tweezers to gently remove the microphone from the slot in the casing.
  7. Oregon Scientific Meep! X2 Screen Replacement: Schritt 7, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 7, Bild 2 von 2
    • Unsolder the microphone unit from the motherboard using the soldering station.
  8. Oregon Scientific Meep! X2 Screen Replacement, Cameras: Schritt 8, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Cameras: Schritt 8, Bild 2 von 2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  9. Oregon Scientific Meep! X2 Screen Replacement: Schritt 9, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 9, Bild 2 von 2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  10. Oregon Scientific Meep! X2 Screen Replacement: Schritt 10, Bild 1 von 1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
  11. Oregon Scientific Meep! X2 Screen Replacement, Motherboard: Schritt 11, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
    • Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
  12. Oregon Scientific Meep! X2 Screen Replacement: Schritt 12, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 12, Bild 2 von 2
    • Remove the two phillips #00 (4.5mm x 3mm)screws located on the motherboard.
  13. Oregon Scientific Meep! X2 Screen Replacement: Schritt 13, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 13, Bild 2 von 2
    • Lift the silver, rectangular blocker in order to expose the right phillips screw #00 (4mm x 3.5mm).
    • Unscrew the left and right phillips #00 (4mm x 3.5mm)screws.
    • Once unscrewed, gently lift the motherboard from the rest of the device.
  14. Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: Schritt 14, Bild 1 von 3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: Schritt 14, Bild 2 von 3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: Schritt 14, Bild 3 von 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  15. Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: Schritt 15, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: Schritt 15, Bild 2 von 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  16. Oregon Scientific Meep! X2 Screen Replacement: Schritt 16, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 16, Bild 2 von 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
  17. Oregon Scientific Meep! X2 Screen Replacement, Screen: Schritt 17, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement, Screen: Schritt 17, Bild 2 von 2
    • Remove the 10 phillips #00(3.5mm x 4mm) screws around the metal framing of the screen.
    • Leave the clear tape on the back of the screen until you are ready to remove it from the white plastic casing.
  18. Oregon Scientific Meep! X2 Screen Replacement: Schritt 18, Bild 1 von 2 Oregon Scientific Meep! X2 Screen Replacement: Schritt 18, Bild 2 von 2
    • Slowly remove the metal frame and screen from the white casing by gently pulling up on the ends of the metal frame.
  19. Oregon Scientific Meep! X2 Screen Replacement: Schritt 19, Bild 1 von 1
    • Remove the plastic tape from the back of the screen.
    • Carefully separate the screen from the metal framing.
Abschluss
USF Tampa, Team 9-1, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 983
