Zum Hauptinhalt wechseln
Oregon Scientific RM318PA Focus Knob Replacement
Was du brauchst
  1. Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: Schritt 1, Bild 1 von 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: Schritt 1, Bild 2 von 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: Schritt 1, Bild 3 von 3
    • Hold Clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Focus Knob Replacement, Batteries: Schritt 2, Bild 1 von 1
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: Schritt 3, Bild 1 von 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: Schritt 3, Bild 2 von 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Focus Knob Replacement: Schritt 4, Bild 1 von 2 Oregon Scientific RM318PA Focus Knob Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Focus Knob Replacement: Schritt 5, Bild 1 von 2 Oregon Scientific RM318PA Focus Knob Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to pry apart the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: Schritt 6, Bild 1 von 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: Schritt 6, Bild 2 von 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: Schritt 6, Bild 3 von 3
    • Turn the clock on its side. Slide the Focus Knob forward with your thumb.
    • The Focus Knob Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Knob.
  7. Oregon Scientific RM318PA Focus Knob Replacement: Schritt 7, Bild 1 von 3 Oregon Scientific RM318PA Focus Knob Replacement: Schritt 7, Bild 2 von 3 Oregon Scientific RM318PA Focus Knob Replacement: Schritt 7, Bild 3 von 3
    • Loosen Focus Knob by turning the Focus Knob counterclockwise with your fingers.
    • If needed, add a SMALL amount of WD-40 to the base of the knob and continue turning Focus Knob.
    • Place replacement Focus Knob in socket and turn clockwise to secure.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 843
