Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A unresponsive device that does not turn on may need the battery replaced. With this guide, learn how to locate the battery compartment and replace the battery.
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
  1. Open the battery compartment by locating the bottom of the handle, and pushing the slider forward. Open the battery compartment by locating the bottom of the handle, and pushing the slider forward.
    • Open the battery compartment by locating the bottom of the handle, and pushing the slider forward.
  2. Take out the battery by pushing down on the red tab. The battery will release, and can be pulled out by using the attached black tab. Take out the battery by pushing down on the red tab. The battery will release, and can be pulled out by using the attached black tab.
    • Take out the battery by pushing down on the red tab. The battery will release, and can be pulled out by using the attached black tab.
Abschluss
To reassemble your device, insert the new battery and follow these instructions in reverse order.
2 weitere Nutzer haben diese Anleitung absolviert.
Ustena Safa
309 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S2-G1, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Mitglieder
6 Anleitungen geschrieben
I have an DJI OSMO Mobile 2 and it does not have such a compartment. It just has a sticker. I was hoping to find details on how to swap the battery in that one.
Roel Van de Paar - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 23
Letzten 30 Tage: 131
Insgesamt: 6,480
