Einleitung
Learn how to take apart the Osmo Mobile handle in order to gain access to other repairs such as the joystick, Bluetooth apparatus, trigger buttons and the charging port.
Was du brauchst
Remove gimbal from base handle by loosening round plate found at the top of the handle.
Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
Carefully detach handle from gimbal and disconnect the cable that connects the two.
Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
Use the spudger to pry open and remove the face plate, starting at the back of the handle.
Locate four screws directly on top of handle.
Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
Remove the remaining two screws found on the front of the faceplate.
Remove the rest of the face plate shell.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
Your help would be greatly appreciated
