Zum Hauptinhalt wechseln
Osmo Mobile Trigger Button Replacement
Was du brauchst
  1. Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: Schritt 1, Bild 1 von 2 Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: Schritt 1, Bild 2 von 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    Frag FixBot
    Kommentar hinzufügen
  2. Osmo Mobile Trigger Button Replacement: Schritt 2, Bild 1 von 2 Osmo Mobile Trigger Button Replacement: Schritt 2, Bild 2 von 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
    Frag FixBot
  3. Osmo Mobile Trigger Button Replacement: Schritt 3, Bild 1 von 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
    Frag FixBot
  4. Osmo Mobile Trigger Button Replacement: Schritt 4, Bild 1 von 2 Osmo Mobile Trigger Button Replacement: Schritt 4, Bild 2 von 2
    • Remove joystick by gently pulling away from handle
    Frag FixBot
  5. Osmo Mobile Trigger Button Replacement: Schritt 5, Bild 1 von 3 Osmo Mobile Trigger Button Replacement: Schritt 5, Bild 2 von 3 Osmo Mobile Trigger Button Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
    Frag FixBot
  6. Osmo Mobile Trigger Button Replacement: Schritt 6, Bild 1 von 3 Osmo Mobile Trigger Button Replacement: Schritt 6, Bild 2 von 3 Osmo Mobile Trigger Button Replacement: Schritt 6, Bild 3 von 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
    Frag FixBot
  7. Osmo Mobile Trigger Button Replacement, Charging Port: Schritt 7, Bild 1 von 1
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
    Frag FixBot
  8. Osmo Mobile Trigger Button Replacement: Schritt 8, Bild 1 von 1
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
    Frag FixBot
  9. Osmo Mobile Trigger Button Replacement: Schritt 9, Bild 1 von 1
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
    Frag FixBot
  10. Osmo Mobile Trigger Button Replacement: Schritt 10, Bild 1 von 1
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
    Frag FixBot
  11. Osmo Mobile Trigger Button Replacement, Trigger Button: Schritt 11, Bild 1 von 2 Osmo Mobile Trigger Button Replacement, Trigger Button: Schritt 11, Bild 2 von 2
    • Use the tweezers to push outward on the backside of the trigger button hinges.
    • Pop out trigger button.
    Frag FixBot
  12. Osmo Mobile Trigger Button Replacement: Schritt 12, Bild 1 von 1
    • Use the tweezers to remove the underlying button that contacts with the trigger button, and replace.
    Frag FixBot
Abschluss
USF Tampa, Team S2-G1, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Mitglieder
18 Anleitungen geschrieben
1 Kommentar zur Anleitung
How I can fix the USB port, it went inside the handle?
Juan Carlos Beltran - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 53
Insgesamt: 3,318
