Zum Hauptinhalt wechseln
Oster 3905 Lever Spring Replacement
Was du brauchst
    1. Oster 3905 Lever Spring Replacement, Slot Levers: Schritt 1, Bild 1 von 1
      • Firmly grip your hand around the slot lever.
      Frag FixBot
      Kommentar hinzufügen
    2. Oster 3905 Lever Spring Replacement: Schritt 2, Bild 1 von 1
      • Stabilize the toaster by placing your hand on top.
      Frag FixBot
    3. Oster 3905 Lever Spring Replacement: Schritt 3, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 3, Bild 2 von 2
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Frag FixBot
    4. Oster 3905 Lever Spring Replacement: Schritt 4, Bild 1 von 1
      • Both slot levers can be removed.
      Frag FixBot
    1. Oster 3905 Lever Spring Replacement, Outer Shell: Schritt 5, Bild 1 von 1
      • Place the toaster upside down so the bottom is facing the ceiling.
      Frag FixBot
    2. Oster 3905 Lever Spring Replacement: Schritt 6, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 6, Bild 2 von 2
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      Frag FixBot
    3. Oster 3905 Lever Spring Replacement: Schritt 7, Bild 1 von 1
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      Frag FixBot
    4. Oster 3905 Lever Spring Replacement: Schritt 8, Bild 1 von 1
      • Place the toaster right side up.
      Frag FixBot
    5. Oster 3905 Lever Spring Replacement: Schritt 9, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 9, Bild 2 von 2
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      Frag FixBot
    6. Oster 3905 Lever Spring Replacement: Schritt 10, Bild 1 von 1
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      Frag FixBot
    7. Oster 3905 Lever Spring Replacement: Schritt 11, Bild 1 von 3 Oster 3905 Lever Spring Replacement: Schritt 11, Bild 2 von 3 Oster 3905 Lever Spring Replacement: Schritt 11, Bild 3 von 3
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      Frag FixBot
    8. Oster 3905 Lever Spring Replacement: Schritt 12, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 12, Bild 2 von 2
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      Frag FixBot
    1. Oster 3905 Lever Spring Replacement, Lever Spring: Schritt 13, Bild 1 von 2 Oster 3905 Lever Spring Replacement, Lever Spring: Schritt 13, Bild 2 von 2
      • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
      Frag FixBot
    2. Oster 3905 Lever Spring Replacement: Schritt 14, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 14, Bild 2 von 2
      • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
      Frag FixBot
    3. Oster 3905 Lever Spring Replacement: Schritt 15, Bild 1 von 3 Oster 3905 Lever Spring Replacement: Schritt 15, Bild 2 von 3 Oster 3905 Lever Spring Replacement: Schritt 15, Bild 3 von 3
      • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
      • Pull the metal spacer upwards to release from the toaster.
      Frag FixBot
    4. Oster 3905 Lever Spring Replacement: Schritt 16, Bild 1 von 2 Oster 3905 Lever Spring Replacement: Schritt 16, Bild 2 von 2
      • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Fullerton, Team 2-1, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Where's the fix?
D Unger - Antwort Teilen
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 3,459
