Einleitung
If your Oster 3905 cord isn’t retracting like the yo-yo you secretly still use, it may be time to replace it. While this replacement guide is pretty straight forward - watch out! There is a nasty little spring that will try to pop out and blind you.
Was du brauchst
Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
Take off both rubber feet using a small metal spudger.
Wedge a spudger under the feet and pull up to pop off.
Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
For this part, you might need to wiggle the toaster to get the outer shell off.
Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
Then use the same screw bit to remove two 10mm screws found at the bottom.
Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
Push down to separate the casing from the toaster.
Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
Eine weitere Person hat diese Anleitung absolviert.
