Zum Hauptinhalt wechseln
Oster 3905 Retractable Cord Replacement
Was du brauchst
  1. Oster 3905 Retractable Cord Replacement, Slot Levers: Schritt 1, Bild 1 von 1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Retractable Cord Replacement: Schritt 2, Bild 1 von 1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Retractable Cord Replacement: Schritt 3, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 3, Bild 2 von 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Retractable Cord Replacement: Schritt 4, Bild 1 von 1
    • Both slot levers can be removed.
  5. Oster 3905 Retractable Cord Replacement, Outer Shell: Schritt 5, Bild 1 von 1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Retractable Cord Replacement: Schritt 6, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 6, Bild 2 von 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Retractable Cord Replacement: Schritt 7, Bild 1 von 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Retractable Cord Replacement: Schritt 8, Bild 1 von 1
    • Place the toaster right side up.
  9. Oster 3905 Retractable Cord Replacement: Schritt 9, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 9, Bild 2 von 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Retractable Cord Replacement: Schritt 10, Bild 1 von 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Retractable Cord Replacement: Schritt 11, Bild 1 von 3 Oster 3905 Retractable Cord Replacement: Schritt 11, Bild 2 von 3 Oster 3905 Retractable Cord Replacement: Schritt 11, Bild 3 von 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Retractable Cord Replacement: Schritt 12, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 12, Bild 2 von 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Retractable Cord Replacement, Retractable Cord: Schritt 13, Bild 1 von 1
    • Rotate the toaster so that the back is facing towards you.
  14. Oster 3905 Retractable Cord Replacement: Schritt 14, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 14, Bild 2 von 2
    • Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
    • Then use the same screw bit to remove two 10mm screws found at the bottom.
  15. Oster 3905 Retractable Cord Replacement: Schritt 15, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 15, Bild 2 von 2
    • Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
    • Push down to separate the casing from the toaster.
  16. Oster 3905 Retractable Cord Replacement: Schritt 16, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 16, Bild 2 von 2
    • Gently tilt the casing towards the toaster as you pull up from the base.
  17. Oster 3905 Retractable Cord Replacement: Schritt 17, Bild 1 von 1
    • Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
  18. Oster 3905 Retractable Cord Replacement: Schritt 18, Bild 1 von 2 Oster 3905 Retractable Cord Replacement: Schritt 18, Bild 2 von 2
    • When opening the casing a metal spring may suddenly pop out.
    • Use the metal spudger to pry open the two halves of the casing.
    • If you are having some trouble only using the metal spudger do not be afraid of using your fingers to pry the casing apart.
  19. Oster 3905 Retractable Cord Replacement: Schritt 19, Bild 1 von 3 Oster 3905 Retractable Cord Replacement: Schritt 19, Bild 2 von 3 Oster 3905 Retractable Cord Replacement: Schritt 19, Bild 3 von 3
    • Carefully remove the spool keeping your fingers on either side of the casing.
    • Tape down the metal spring to keep it from unraveling out of place.
  20. Oster 3905 Retractable Cord Replacement: Schritt 20, Bild 1 von 3 Oster 3905 Retractable Cord Replacement: Schritt 20, Bild 2 von 3 Oster 3905 Retractable Cord Replacement: Schritt 20, Bild 3 von 3
    • Carefully unwind the power cord from the spool.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Fullerton, Team 2-1, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 560
