Einleitung
From frequent use, over time, slot levers may become unstable to the touch and fall off. This replacement guide will show you how to remove your current damaged levers. When doing this, you may feel like you are going to pull too hard, but do not worry about that. You will need to pull the on the slot levers with a lot of force.
Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
