Einleitung
This repair is challenging because the wire that acts as the spring is difficult to bend into the correct shape.
Was du brauchst
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
Repeat this step for the opposite side.
2 weitere Personen haben diese Anleitung absolviert.
