Einleitung
This guide requires that you know how to solder components and identify which component needs to be replaced.
Was du brauchst
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
Using a #1 phillips head screwdriver, remove the four 1cm philips head screws holding the circuit board to the inside of the toaster shell.
Inspect the circuit board for any burnt or otherwise damaged components. Be sure to carefully identify the damaged components that need replacement. For help identifying resistor values look at wikipedia's electronic color code article.
Use the soldering kit to unsolder the damaged component. For soldering Instructions look at the iFixit Soldering Guide.
Once the damaged component has been unsoldered from the circuit board, remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
