Einleitung
The power cord is responsible for providing power to your device. This guide will instruct you on how to replace the power cord.
Was du brauchst
Use the prying tools to open the four plastic screw holes on the bottom of the blender.
Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
Use the spudger to detach the black wire from the circuit board.
Repeat for yellow wire.
Use the Phillips #1 to remove the four 8mm screws.
Use the medal spudger to detach the circuit board from the buttons.
Gently pull and release circuit board from buttons.
Locate petal prong on the end of the power cord.
Bend metal prong until it's straight with your finger.
Pinch plastic prongs on base of blender to remove plastic securing device.
Remove plastic securing device.
Pull power cord out of blender base.
