Zum Hauptinhalt wechseln
Oster BLSTSS-PZO Power Cord Replacement
Was du brauchst
  1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: Schritt 1, Bild 1 von 1
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 4, Bild 1 von 2 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 4, Bild 2 von 2
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 5, Bild 1 von 3 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 5, Bild 2 von 3 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 5, Bild 3 von 3
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: Schritt 6, Bild 1 von 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: Schritt 6, Bild 2 von 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: Schritt 6, Bild 3 von 3
    • Locate petal prong on the end of the power cord.
    • Bend metal prong until it's straight with your finger.
  7. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 7, Bild 1 von 2 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 7, Bild 2 von 2
    • Spring will pop out when you pull out metal prong
    • Pull prong out of the hole.
  8. Oster BLSTSS-PZO  Power Cord Replacement: Schritt 8, Bild 1 von 3 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 8, Bild 2 von 3 Oster BLSTSS-PZO  Power Cord Replacement: Schritt 8, Bild 3 von 3
    • Pinch plastic prongs on base of blender to remove plastic securing device.
    • Remove plastic securing device.
    • Pull power cord out of blender base.
Abschluss
Loren Hyer
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 191
