Zum Hauptinhalt wechseln
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
Was du brauchst
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: Schritt 1, Bild 1 von 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: Schritt 1, Bild 2 von 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 2, Bild 1 von 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 2, Bild 2 von 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 2, Bild 3 von 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: Schritt 3, Bild 1 von 1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 4, Bild 1 von 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 4, Bild 2 von 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 4, Bild 3 von 3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: Schritt 5, Bild 1 von 1
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 6, Bild 1 von 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 6, Bild 2 von 2
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 7, Bild 1 von 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: Schritt 7, Bild 2 von 2
    • Press new seal into seal seat with finger.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Paul Long
710 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 12-6, Blackwell Fall 2015 Mitglied von USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 860
