Zum Hauptinhalt wechseln
Oster CKSTSTMD5-W Disassembly
Was du brauchst
  1. Oster CKSTSTMD5-W Disassembly, Oster CKSTSTMD5-W Disassembly: Schritt 1, Bild 1 von 1
    • Remove the plastic steamer tiers and make sure the device is unplugged.
  2. Oster CKSTSTMD5-W Disassembly: Schritt 2, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 2, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 2, Bild 3 von 3
    • Flip the device upside down so that the sticker is facing upwards.
    • Using your hands, carefully pry out the four rubber feet from each of the corners.
  3. Oster CKSTSTMD5-W Disassembly: Schritt 3, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 3, Bild 2 von 2
    • Using the JIS #1 screwdriver, remove four 12 mm screws from the four holes.
  4. Oster CKSTSTMD5-W Disassembly: Schritt 4, Bild 1 von 1
    • Once the four screws are removed, lift the bottom of the device off of the frame.
  5. Oster CKSTSTMD5-W Disassembly: Schritt 5, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 5, Bild 2 von 2
    • Use a pair of scissors to cut the zip tie binding the blue and brown wires together.
  6. Oster CKSTSTMD5-W Disassembly: Schritt 6, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 6, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 6, Bild 3 von 3
    • Using a socket wrench with a 7 mm bit, unscrew the nut from the center of the metal ring.
  7. Oster CKSTSTMD5-W Disassembly: Schritt 7, Bild 1 von 1
    • Remove the nut and the two washers from the center bolt.
  8. Oster CKSTSTMD5-W Disassembly: Schritt 8, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 8, Bild 2 von 2
    • Lift off the metal brace from the bolt in the center of the device.
  9. Oster CKSTSTMD5-W Disassembly: Schritt 9, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 9, Bild 2 von 2
    • From the center of the device, carefully grab the blue wire and lift the thermal fuse from its socket.
  10. Oster CKSTSTMD5-W Disassembly: Schritt 10, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 10, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 10, Bild 3 von 3
    • Using your hands, carefully lift the wires over the center bolt so that they are out of the way.
  11. Oster CKSTSTMD5-W Disassembly: Schritt 11, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 11, Bild 2 von 2
    • Using your index finger, carefully pry the metal sheeting out from under the wires.
  12. Oster CKSTSTMD5-W Disassembly: Schritt 12, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 12, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 12, Bild 3 von 3
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the left side of the device.
    • Lift off the white plastic brace.
  13. Oster CKSTSTMD5-W Disassembly: Schritt 13, Bild 1 von 1
    • Lift the white power cord out of its socket.
  14. Oster CKSTSTMD5-W Disassembly: Schritt 14, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 14, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 14, Bild 3 von 3
    • On the left-hand side of the device, carefully remove the indicator light from its place next to the timer by pulling on the heat protector covering the brown wire.
    • Be careful to ensure the bulb stays attached to the wire.
  15. Oster CKSTSTMD5-W Disassembly: Schritt 15, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 15, Bild 2 von 2
    • Using the JIS #1 screwdriver, remove the two 12 mm screws attached on each side of the timer.
  16. Oster CKSTSTMD5-W Disassembly: Schritt 16, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 16, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 16, Bild 3 von 3
    • Using your hands, carefully lift the white plastic barrier out of the device from the right side of the timer.
    • Be careful not to impede the blue and brown wires connecting the heating element to the timer.
  17. Oster CKSTSTMD5-W Disassembly: Schritt 17, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 17, Bild 2 von 2
    • Rotate the device so that the dial faces you.
    • Using the plastic opening tool, pry the white dial out of the timer socket.
  18. Oster CKSTSTMD5-W Disassembly: Schritt 18, Bild 1 von 1
    • Pull the white dial the rest of the way out of the socket.
  19. Oster CKSTSTMD5-W Disassembly: Schritt 19, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 19, Bild 2 von 2
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the top and bottom of the timer socket.
  20. Oster CKSTSTMD5-W Disassembly: Schritt 20, Bild 1 von 1
    • Using your fingers, pry out the black timer socket from the front hole.
  21. Oster CKSTSTMD5-W Disassembly: Schritt 21, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 21, Bild 2 von 2
    • Using your hands, carefully lift the timer out of the socket and away from the device.
    • Be careful not to pull too hard as to not break the wire connection.
  22. Oster CKSTSTMD5-W Disassembly: Schritt 22, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 22, Bild 2 von 2
    • Using the JIS #1 screwdriver, remove the two 4.3 mm screws from the right and left side of the timer.
    • Using your hands, lift off the black plastic cover.
  23. Oster CKSTSTMD5-W Disassembly: Schritt 23, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 23, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 23, Bild 3 von 3
  24. Oster CKSTSTMD5-W Disassembly: Schritt 24, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 24, Bild 2 von 2
    • Using the plastic opening tool, bend the 3 metal braces towards the outside of the timer so that the metal fits through the slots.
  25. Oster CKSTSTMD5-W Disassembly: Schritt 25, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 25, Bild 2 von 2
    • Lift the silver cover off of the timer.
  26. Oster CKSTSTMD5-W Disassembly: Schritt 26, Bild 1 von 1
    • Lift the metal silver plate off of the timer.
  27. Oster CKSTSTMD5-W Disassembly: Schritt 27, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 27, Bild 2 von 2
    • Using the JIS #1 screwdriver, remove the single 4.3mm screw from the top center of the timer.
  28. Oster CKSTSTMD5-W Disassembly: Schritt 28, Bild 1 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 28, Bild 2 von 3 Oster CKSTSTMD5-W Disassembly: Schritt 28, Bild 3 von 3
    • Lift the black plastic casing out from in between the front and back of the timer.
  29. Oster CKSTSTMD5-W Disassembly: Schritt 29, Bild 1 von 2 Oster CKSTSTMD5-W Disassembly: Schritt 29, Bild 2 von 2
    • Rotate the timer 90 degrees to the left so that you can see it from the side.
    • Lift the silver back casing off of the timer.
Abschluss
Angehängte Dokumente
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 177
