Zum Hauptinhalt wechseln
Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Was du brauchst
  1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Top Panel Removal: Schritt 1, Bild 1 von 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 2, Bild 1 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 2, Bild 2 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 2, Bild 3 von 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 3, Bild 1 von 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 4, Bild 1 von 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 4, Bild 2 von 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: Schritt 5, Bild 1 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: Schritt 5, Bild 2 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: Schritt 5, Bild 3 von 3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 6, Bild 1 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 6, Bild 2 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 6, Bild 3 von 3
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 7, Bild 1 von 1
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 8, Bild 1 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 8, Bild 2 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 9, Bild 1 von 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 9, Bild 2 von 2
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 10, Bild 1 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 10, Bild 2 von 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 10, Bild 3 von 3
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 11, Bild 1 von 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: Schritt 11, Bild 2 von 2
    • Remove lining.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S7-G5, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 477
